Media player, sort files
Zaltais
Explorer
i resently got a Sony Bravia KDL-46W905A
What im trying to do is only view the video files in a specific folder on my server while also having them sorted by file name A to Z.
While using the media player under applications i select Video as my media and i'm able connect to my server just fine.
When i select all videos the media player shows them sorted and i'm able to change the order they are sorted in.
If i select by folder it shows the corret folders and i'm able to navigate them, but the folders and files are sorted by date, and trying to change how they are sorted with options and sort by doesn't change the order of the folders or files.
would love some input on how to only view the videos in a specific folder while also having them sorted
2 REPLIES 2
profile.country.en_GB.title
Catmambo
Contributor
Maybe depends on the DLNA software on your computer? Mine are sorted alphabetically automatically.
Zaltais
Explorer
just curious, are you able to change the order they are sorted while viewing by folder ?
