- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony KDL-47W805A :I have a Sony kdl-47w805a which shows the following message when I try to open iPlayer
"tv internet download failed because content size exceed system memory limit."
Can I clear or increase the memory or can I not get iPlayer anymore ?
What does it actually mean ?
My tv is only 3 years old.
Thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
permanent fix because the problem seems to be the TV's 'memory'. If you
have Amazon firestick you can use this to bye-pass the TV's inadequate and
its dodgy memory.
Sony are obviously content to do nothing although why beats me given the
unfavourable publicity this is generating.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@jimtyro - interesting that you say a factory reset temporarily works. Can you estimate how long or how many shows etc that this temp fix works? Also what model TV do you have:? Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from Samsung Mobile on O2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I am afraid I can't. I bought the TV from John Lewis and it was their complaints team who talked me through the process. It has worked well since but I also use Amazon fire to connect and that means I have not used the usual iPlayer logon frequently. I was told by JL that the Bravia range all seem to suffer from low capacity memories so its only a matter of time before they fail, whatever vintage you have. Pity, they otherwise good TVs but my next one will not be a Sony set unless I have very good evidence that they have sddressed this problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Wednesday 23rd August 2017; System memory limit message has come up on screen when streaming BBC iPlayer
Is this problem in the process of being rectified as I note that it has happened before and has been quickly resolved?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Strangely this is the first time we have encountered this problem when
using the BBC iPlayer having owned our television for just over
3 years now. It obviously is resolvable because other communications via
Sony evidence this in the past.
[Personal details removed by moderator]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yet. There is no long term solution except work around either by doing a
factory reset every so often or using an alternative browser such as
firestick.
Shame because its otherwise a very good TV. Sony seem to be utterly
unconcerned about it which I find odd.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPhone
