Debbie-54
New
KDL 46EX650
I bought a Sony Bravia KDL 46EX650 overseas and brought it home to the USA.  I wanted to hook in my cable connection to the TV but the cable connections on the TV are not able to be connected to the antenna cable fittings from the Cable company.  Is there a different cable I need to have to connect the Overseas cable connection on the TV to accept a USA cable connection?
2 REPLIES 2
EdwinaU
Moderator
Hi Debbie,
Welcome to the community.
We'll check this and update you as soon as we can. Meanwhile, some other members may have some information they can share.
Best wishes,
Ed
Tenneen9000
Member
Hi Debbie,
I don't think that cable connection will be possible as the US and the EU both have their own standards when it comes to connections in general. However, you can always check with your cable company or if possible, have the cable connected to an external box and connect the box via HDMI.
Cheers,
Tenneen9000
