I have perchased a KDL-46W905A Bravia and can not find a way to download new apps.
Have serched on Google but only found a youtube from Sony about a Android market app to download apps with but i dont have the market app?
Opgelost! Ga naar oplossing.
gostaria de estalar globo play na minha tv
How do I download new apps to my Bravia TV
How to download Kodi for KDL 48WD650
Wd6 is not Android... you cannot install anything apart what is available on opera store
Is that correct that - I have a KDL-40WD653 and want to load some more apps as those in the Opera Store are very limited and US centric. If this is not an android TV then its going back
Hi there
The KDL-40WD653 is indeed NOT an Android based TV. You can see this for yourself, by pressing the HOME button on the remote control. The home screen should look much like this picture:
Android TV models can be found:
https://www.sony.co.uk/electronics/tv/t/televisions?type=android-tv
Cheers
I have a Sony 32 WD 756 Smart TV. How do I get new apps and access to the internet other than the standard apps.?
Hi there
You can only use the apps that are currently installed on the TV as well as the ones that are in the Opera TV Store. The WD7 series TV does not include a web-browser unfortunately.
Cheers
vil gerne havde viaplay på vores smart tv
Hi leschott
Thanks for your post. As this is the Sony UK Community forum, it would be helpful if your contributions were in English
Best wishes
Mick_D
Community Manager
