surfinjo
Explorer
Compare Sony TV
Looking at Sony Bravia KDL32 WE613 and Sony Bravia KDL32 RE403
Both appear to have same features, including Smart TV. But the 613 claims to have Full Smart TV.
Does anyone know the difference between Smart TV and Full Smart TV please?
https://www.amazon.co.uk/Sony-KDL32RE403-32-Inch-X-Reality-Recording/dp/B06WD4S2Z8/ref=sr_1_5?s=home...
https://www.amazon.co.uk/Sony-KDL32RE403-32-Inch-X-Reality-Recording/dp/B06WRSJCBD/ref=sr_1_5?s=home...
2 ACCEPTED SOLUTIONS
Accepted Solutions
Anonymous
Not applicable
Hi there
Thanks for flagging this.  The KDL-32RE403 is NOT a Smart TV.  Amazon has listed this incorrectly.  I have sent an email to my contact within Sony for them to get this corrected.
The KDL-32WE613 is indeed a Smart TV.
Cheers
Anonymous
Not applicable
Hi there
I think the best thing to do is point you to Sony's Support website as this is correct.
Specifications:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-32we613/specifications
It states that Bluetooth is not supported.  However there is a work-around in regards to headphones for you.  You will need purchase wireless headphones that connect to the TVs headphone socket.  The TV can then be set to output audio via the headphones AND the TV speakers. So that means that you can adjust the TV volume to a different level than that of the headphones.  Just ensure that the headphones you purchase have is own separate volume control.
Alternatively, if you really do want a speaker next to you - you can purchase a Bluetooth transmitter that connect to the TVs headphone socket.  There are many on Amazon.
Further information can be found in the manual:
https://www.sony.co.uk/electronics/support/res/manuals/4689/46896421M.pdf
Cheers
4 REPLIES 4
Anonymous
Not applicable
Hi there
Cheers
surfinjo
Explorer
Thank you for your prompt response. Pleased that has been cleared up.
Currently looking for a new TV and Sony seems to be the place to go now.  The WE613 seems to be perfect.
Can you say if the features listed for the WE613 are as stated on Amazon?
Also, though not listed, is possible to fit Blue Tooth? Or similar?
My hearing isn't brilliant any more and I'd like a small speaker next to me, rather than annoy the whole of the neighbourhood with the volume set too high! Wires are out of the question.
Thanks again. Jo
Anonymous
Not applicable
Hi there
Specifications:
Cheers
surfinjo
Explorer
Thanks so much. That is brilliant.
