- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2014
January 2014
Hi everyone, very non technical 40 something here and would like to know the best way to connect a Bravia 46w905abu to a ct660 soundbar. I'm currently using an optical lead. Many thanks
Solved! Go to Solution.
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Hi there
The best way (in my oppinon) is to connect the HT-CT660 to the TV via a HDMI cable - removing the optical completely. This should also give a mainly single remote control solution.
What you need:
1 x HDMI 1.4a cable (note: it must be a 1.4a version)
How to connect it:
- Disconnect and remote the optical cable between the two
- Connect the HDMI 1.4a cable to the TV's HDMI 1 (ARC) port and to the CT660 HDMI TV OUT (ARC)
- Enable Bravia Sync on the TV and CT660
Hope this helps
2 REPLIES 2
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Hi there
What you need:
How to connect it:
Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2014
January 2014
Will give it a go. Many thanks
