I have Xperia M2 with 4.4.4 update. When i type any text, keyboard doesnot make first alphabet capital !!!
My keyboard software version is 6.4.A.1.24
Opgelost! Ga naar oplossing.
Hi S4chin,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you using the default messaging app, as in most cases it is based on how the application has been developed, if the code is missing it will not default the Capital on the first word.
However this should work without issues on the default messaging app.
Can you try settings-apps-all-xperia keyboard,clear data? IT will remove your words.
Hi S4chin,
hmm, right Jake. Its working good with default apps.
After clearing data it also working ok with other apps @Alex
ThnX
Great, im glad we could be of assistance
