trying to telephone the uk ,from crete , no joy , I'm in roaming mode and normally everything works fine until now, I have notifications for voicemail but unable to call it or make any calls to the UK, I've obviously added +44 etc. Completely baffled, any suggestions please.
Thank you.
Solved! Go to Solution.
Hi Martin
"You are a complete genius"
The only thing that you told me to try which I didn't until you mentioned it again was to go onto the 3g network, just done that and everything is back to normal !
You obviously know your stuff and I really appreciate your time and help, I would of never sorted this without your help.
Thank you so much, if I ever meet you, I owe you a pint, you're a gentleman.
Thanks again
Regards
Ray.
No worries, @Sascom ! I am glad that I could be of assistance!
Feel free to get back to me if you have any further questions in the future regarding your phone and have a wonderful time in Greece!
Thanks Martin, you're a life saver and I'll try to enjoy Greece 🇬🇷 although I have other problems which you wouldn't be able to solve, the holiday is with Thomas Cook, getting home I suspect will be a bit of a challenge.
But thanks again and your help was fantastic and I'll click on the box that says your advice solved the problem.
Take care
Ray.
Again, Glad I could help!
Ah, that is a bit of a pickle that i believe is out of my reach. Nevertheless, I wish you all the best and i hope that you'll get home safe and sound!
Sincerely,
Martin
