My apps stop working
RVG6
Bezoeker
Hola, algunas de mis app dejan de funcionar cusndo las ejecuto, estas app en algun otro momento me funcionaron ke puedo acer Screenshot_20190917-013131.png
Hello, some of my apps stop working when I run them, these apps at some other time worked for me that I can
-GT
3 ANTWOORDEN 3
Martin1
Fan
Hi @RVG6, let me see if I can help out here!
Your post has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Have you tried clearing the data for the applications that are malfunctioning? By clearing data, you will reset all settings for the app which might do the trick. To do this, find and tap Settings > Apps > Tap the app that is malfunctioning > Storage > Clear data > Tap "OK" > Restart the phone.
If there is a pre-built app that is malfunctioning, you may also try rebooting your phone in safe mode to see if the app stops there as well. Safe mode is a troubleshooting mode where all downloaded apps are deactivated temporarily and by rebooting to safe mode, you can see if this behaviour is caused by a downloaded app. For more information on safe mode and how to use it, click here
Try this to begin with and feel free to keep me posted with the results!
RVG6
Bezoeker
Thanks, I will try it
Martin1
Fan
Sounds great, @RVG6!
Keep me posted with the results and let me know if you have any further questions!
