Seconds in the rain
There is nothing in life like true friendship and the joy it brings even in the rainiest of weathers!
Wat is Exif data
Software Niet beschikbaar
Witbalans Niet beschikbaar
Flits status Niet beschikbaar
ISO Niet beschikbaar
Brandpunt Niet beschikbaar
Kleurbereik Niet beschikbaar
Objectief Niet beschikbaar
Opmerkingen
profile.country.en_GB.title
tweety2b
This winner was selected as this month's winner.
This is the explanation Paolo gave us for his choice:
E' un'immagine con una grande energia. La composizione è semplice, ed efficace.
Si percepisce la gioia del momento, la dinamicità del movimento, così come si percepisce molto bene la pioggia, che è l'altro elemento fondamentale dello scatto.
Nel complesso una foto tecnicamente corretta, scattata con il giusto tempismo per trasmettere correttamente l'emozione osservata.
An image with a great energy. The composition is simple, and effective.
You can feel the joy of the moment, the momentum of the movement, as well as you can feel the rain, which is the other key element of the shot.
Overall a technically correct photo, taken with the right timing to convey the observed emotion.
Kindest regards,
Nico
StartTheCar
Super shot, wonderful timing.
