Sony 2012 Catalogue
SOLVED
profile.country.en_GB.title
KushMonkey
Visitor
Sony 2012 Catalogue
Hi. Is it possible Sony can send one to me? Many thanks. :slight_smile:
1 ACCEPTED SOLUTION
Accepted Solutions
-Cass-
Explorer
Hi KushMonkey,
Welcome to the forums.
Unfortunately Sony no longer print catalogues.
However, you can find all the information on all ranges of Sony products on the Sony website here.
Kind regards,
Cass
Forum Moderator
3 REPLIES 3
-Cass-
Explorer
Hi KushMonkey,
Kind regards,
Cass
Forum Moderator
mydearcosmo
Visitor
I have the same question. Can I print any manuals Sony has online? Or are there none?
carpetmojo
Member
There's everything easily available - go to Support, top of this page, then Reader support, then select your model, and.... there :slight_smile:
