S have a UK Sony TV model KDL-40HX803 I am trying to find out how you name the HDMI inputs. Sony have told me that it is not possible but when I had the TV installed the installer named 3 of these inputs so I know it can be done I just cannot find how to do it.
Opgelost! Ga naar oplossing.
Hi there
The only way that I know is if you give the input a "label"
Hope this helps
Cheers
