Hi all I am looking for a right angled adapter for the VCT SGR1 grip. A normal micro USB does not work. Does anyone know where I can get one from?
Hi,
Something like this?
https://www.amazon.co.uk/Cablecc-Connector-Degree-Extension-Adapter/dp/B01787L60A
Cheers
Hi there! Did you had any luck in finding an multiport angled adapter? I am also looking and didn't had any luck in finding one. Thanks!
