- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, after update in this section http://www.static.xperiablog.net/wp-content/uploads/2015/07/Android-5.1_Xperia-Z3-Compact_2-315x560.... gone 4G link, maybe someone know how to add it or possible to add and ect? If no maybe is bug? Very was useful link. thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@euphorics, no. I don't have the dual but I have the Xperia C5 with Lollipop 5.1, you just swipe down twice the notification area, just right after the battery you'll see a pencil - press that, it's to edit the notification area.. then swipe left and right to find the LTE/4G icon and just drop it to an empty space...
... I don't really want to think that the dual is different from the single sim!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Unregistered user
could you elaborate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can u see pic? I posted link. U know in Lollipop when u throw down screen is section where is wifi link, plane mode, bluetooth and ect. Before i updated was 4G i could just push easy 4G and turn on/off it. Now after update i must go in settings of mobile. I don't know how this section calling, but u can find it in up near notification senction. Just need to down it with throw down. I posted pic. Try open link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Unregistered user
what if you pull down the notification bar > tap on the edit icon > look for the data icon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Unregistered user,
Just to clarify, you're wanting a shortcut to enable and disable 4G only, and not your mobile data entirely?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Cameron, yes u arebright, i want 4G disable and enable. After update from Lollipop 5.0 to 5.1 this option gone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Uliwooly sorry maybe i'm bad explain u, but i know how to turn on and off internet, mobile data. I need 4G to turn on or off option. This option gone after update and now possible to turn on/off only in settings, but not in notification bar 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately @Unregistered user, this is no longer an option from the Quick Settings menu. You will have to install a third party widget in order to have access to this shortcut.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
CameronT, ok. Thanks a lot of 😉 I hope in next update will added again, very useful was 😉
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
