Hello and sorry for my broken inglish.
The case is the next: before the marshmallow update i have in screen>daysleep(protector de pantalla) that shows me random pics from my gallery when the cellphone it is recharging the battery and after the update I only have two of the four options (colors and Google photos) and i Just want to know why this changue
Thank You for reading and Your time
Solved! Go to Solution.
oh i see, well as with the latest xperia devices those are the only options availble, maybe you can try to download a screensaver app on google play store.
have you tried to check the google Photos option? it allows you to select images stored in your device
The thing whit Gp is if i have 100 pics always (i dont see anything to change it) goin to show 1-2-3... And whit the other options at least is "random"
Thank You anyway
@Hector199 wrote:Hello and sorry for my broken inglish.
Probably answer you can say just Sony's engineers which modified Marshmallow software. I'm not sure at all that this is Sony's feature, it can be part of android operating system which is Google product. For example: Smart Lock - feature is developed by Google™ and the exact functionality may change over time due to updates from Google™. So with Daydream can be the same
Thank You to evryone o reply my, i think that i goin to searsh for a app, is not a big problem for the device but that s****
Really Thank You to evryone
