Xperia C5 Ultra Camera Loading Time & Performance
Write2Sameh
Visitor
Why does the camera take forever to load and snap photos on the Xperia C5 Ultra? Everything else is pretty much great and quite fast to open up but the camera and it's different modes seem to take a toll on the phone's performance. Eventually it works well and takes good photos but for a phone that was sold to me simply because it has the best selfie camera in the market... the one feature which I use the most is annoyingly slow. Will Sony fix this in the next update or is this something I just need to live with?
13 REPLIES 13
Write2Sameh
Visitor
This problem is because of google now. There was a post about this in the forum.
Disable the Google Now voice command and that should fix things for you. The post I am referring to has a step by step explanation.
Good luck.
bounsir
Visitor
Even withouth the Google now voice it still is slow
Write2Sameh
Visitor
I completely agree. I used to have a xperia Z2 and that phone had the same ram and comparable processing power. The camera was fast to load and the phone's performance was overall great. The C5 Ultra has some serious performance issues and I am hating the amount of time the camera loads and especially the time it takes for a picture to load after I take a snap. Uninstalling the google now launcher and disabilling the voice command helped but was not the solution to this issue. I tried everything to fix this but the only thing I can say is we probably just need to wait for the upgrade to Anroid M. Hopefully that will fix things up.
kyu_44
Visitor
I had already updated my OS to marshmallow but still, the photo is so slow to load....any solutions to this vintage problem?
