This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Reinstall the latest update with PCC, it will smooth things out
Bridge (for Mac)
Today I found this
I REALLY do hope it'll fix issues with camera and GPS. I can't afford to buy a new phone at this moment (otherwise I'll get be Asus Zenfone 2 months ago).
Another reason to complaint- calendar sync. It happend second time already- it stopped to show all calendar events on one of the Exchange accounts (emails and contacts are there). The only way to fix is to remove account and re-add it again.
Xperia C3 Dual is a complete failure as of now. Great phone with a lots of potentials- and Sony just blew it.
Blu Products gettings Blu Pure XL on a market at the end of September - I better spend money with them (or Asus Zenfone 2).
After so much waiting, talking to Sony about repair (warranty issues) I bought me Asus Zenfone 2.
Sony has a better design, better skins and more logic in interface, but I need a smartphone for my living (I do work on it a lot).
The end.
I hope Sony will sart to sell all fo tehir models in USA, not just couple of them.
Hello Sony Community. I'm new here. Acquired my Sony Experia T2 Ultra and Sony Experia C3 D2502 around March 2015. I never had any problems whatsoever with the stock Android KitKat 4.4.2.
I've been researching a lot about this update. Last week, I decided to give Lollipop 5.1.1 Build number 19.4.A.0.182 a go on my Experia C3. Overall the system is fine. Games running very smoothly and system memory management is doing surprisingly well compared to Kitkat. It's like Windows 8/8.1 of PC.
However.........
I've got 3 issues at hand after I made the 19.4.A.0.182 update : 1. Rear camera; 2. Google Apps date; 3. Walkman app renamed to a generic name "Music". (I always restart my phone every 8am since last week just to check)
1. Rear Camera:
At first glance, the picture and texture looks crisp and fantastic but after zooming in, every shot I took looked the same way ---- like a smudged painting. No matter what setting I used, it still gave the same results e.g Superior Auto and Manual. To my recollection, Front/Rear Camera worked flawlessly on KitKat.
2. GOOGLE APPS Date:
See snapshot below and focus on the date 01/01/1970. Other apps are ok and will give you the installation date. On the other hand, GOOGLE System Apps will give the 01/01/1970 regardless of current date e.g. Music, Album, System Webview, etc. etc...., reinstalled Google Play services through Google Play Store by PC, Google Play Games etc .., I even tried altering the internal system date and time to isolate the problem but still gave the same results..Now I am not so sure how to rectify this.
