Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
rajpa
Visitor
Sony,
 First of all my warranty going to expire on 11th January 2016 and i want an answer immediately realed to my mobile problems,
I have seen in my phone Music is not working after half and hour and it get start automatically.
When I called to someone my voice can't reach properly to them may be it's mic problem.
when i go to service centre they first of told me to update your phone and they solved both problems mic and music but when they updated my phone it has some issues
1. icons are blur.
2. camera clarity is like painting
3.when i add google account it show me available updates and restore message in notification after click on available updates then click on update all apps its start downloading but when i go back from playstore all downloading is stop. (i aslo checked queue bacground data in battery option its off.)
4.when i open play store it show me error "unfortunately google play store stop working" every time it shows me continuosly.
this problem after service centre updated my phone.
please help me because my warranty expire on 11th january 2016
Model C3 dual D2502
Android 5.1.1
Update 19.4.A.0.182
>>open this first image in zoom u will see its painting effect and sometime in normal photo also its like painting.
DSC_0003.JPGScreenshot_2016-01-09-11-21-26.pngScreenshot_2016-01-09-11-15-03.pngthis image when i click on search button on playstore for appDSC_0004.JPG
AutumChris
Visitor
There's an app in Play Store called Open Camera, reduce the ISO to 200-400. That should reduce painting effect by a little.
There are no fixes for this camera bug yet, so you're out of luck.
Mindmicro
Visitor
Hi, im xperia c3 user from indonesia.
After update to lolipop 5.1 Rear camera is veryvery bad. While taking the photos it look like usually i see. But after zoom in the photos its so blurry like a pieces. I have same problem like this with my xperia M2 but after receive lastest firmware a month ago the camera back to normally. I hope my xperia c3 also receive the newest firmware to fix this problem.
Please help, sony.
Thank u from indonesia
Ajith5
Visitor
5.1.1 is good but kitkat is still best
Jailboi
Visitor
HELLO THERE... I WANTED TO KNOW IF I CAN CHANGE MY CAMERAS SELF PORTRAIT LIKE THE SELF PORTRAIT IN XPERIA C4, MINE IS C3 BUT I DIDN'T LIKE THE SELF PORTRAIT HERE SO CAN I DOWNLOAD SOME APPS??? Please help me me to know..
Hopefully
Jailboi
Thiruz
Visitor
Oh it's too important for Sony
1. My new contacts cannot be add directly to the Google account, feeling uncomfortable so sad after the lollipop update
2.during call we can't able to make a new call there is only a red button to end call there is no option to make a new call to put conference
Thiruz
Visitor
I search on Google for maintenance of battery 🔋 life
1. I seen that if your battery is li-ion battery we can't full charge it and also can't full discharge it
if we do opposite for that the battery cycle was reduced.
I want to know whether it is Wright wrong because it's a latest technology batteries so I don't know
what's your opinion
rajpa
Visitor
It doesn't sense to install this app, this phone is specially built for camera with rear 13MP and front 5MP. If you know this issue with lollipop update than you should fix this issue with update, i try to click pics with your suggested app called open camera same issue persist and this problem after update there was no issue on kitkat. I visited service centre for music and microphone problem what i get, is sony's best camera with inbuilt painting effect. They told that its take one day for fix this issue of music and microphone but to solve error of google playstore and camera problem service centre take over 2 months. Thats why i bought sony?
cy1996
Visitor
My c3 has a problem with it‘s message and it always have a delay ,I am so upset about it,and what can I do for it. PLEASE HELP ME!!!!!!!!
Ukay
Visitor
So it's better I stick with kitkat? I keep getting prompt to upgrade to lollipop on my c3. Or is it fixed now?
