This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Nope. Notice how the mods and staff only appear for certain errors and problems? Even the senior members here stay away from this problem.
If the 5.1 update doesn't fix it, I'll start installing CyanogenMod 12.1. Someone finally started development and anything would be an improvement especially when no news comes to us consumers from the company developers.
after purchasing c3 its a dream comes true!!
but now its turning to be a worst nightmare
after taking pics from rear cam after 2 months pics start to look grainny when zoomed looks more like cheap vga cams .front cam was grt .I constantly update my phone to the latest specs when a notification arrives in it.
Now after upgrading it to lollypop it detoriated even further rear cam is pathetic front cam pics was not up to the mark,apps crashes very often . Recently it is on NEOSA ELECTRONICS RSHBEHARI cz it is restarting frequently the service center executive told me it will took 5 days more..and cam problem will solve after update to 5.1.1 .
SONY PLZ SHEAD SOME LIGHT INTO THIS ISSUE AND MAKE ALL C3 USERS COMPLAIN FREE .
Don't create duplicate posts, you can contact Sony directly as this is a user based forum
Kindly state your problem, may be we can assist you.
