This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Hello,
I am not found user menu in setting option .?? (like setting -> user ) not found .
how can i add multiple user facility in my Xperia C3 Dual phone .??
After update also front camera clearity very poor .. its dark capture also when flash are available .. sometimes its going to white nothing capture in image only white photo.. ?/
Thanks,
JIGAR
Neither the C3 nor the T2 Ultra have multiple users, it has been asked before, and we are still waiting for an official statement
Hi team ,
Need a big time help got my C3 dual updated to lollipop , from then facing a lots of problem lagging, worst camera clicks call attending and call making problem went to service center and updated again to loliipop through ther system procedure everything seems alright but, the biggest concern is front camera best selfie camera is now worst selfie , in bright places it captures very bright white and in low light places very dark how worst thbis looks please sony i need the answer from you
