Whats the differences between updating system software without pc and update with pc.
Solved! Go to Solution.
With a computer you have the option to reset the phone which is a good idea if your phone has been acting up
Thank You for your reply and answer.:)
If i update the system, Is there errors after the update. Or i should go to the service centre(it costs i lot:)) ?Plz if u have time ,can u tell me a tutorial to update my c5 5.0 to 6.0:)?
@p2o98 wrote:If i update the system, Is there errors after the update. Or i should go to the service centre(it costs i lot:)) ?Plz if u have time ,can u tell me a tutorial to update my c5 5.0 to 6.0:)?
I'm owner of Sony Xperia C5 Ultra Dual, after update into Marshmallow i saw these problems:
1. Smartphone is little slower, in transfer to SD card moment freezing, can stop to work and restart. Sometime freezing without any reason. But this happen not so often, but happening sometime.
2. Battery draining for me more as was in Lollipop 5.1 and much more as was with Lollipop 5.0. For example if in Lollipop 5.0 did not drop any % over night in stand by and after 8 hours or more little bit after 100% i found 100%, in Lollipop 5.1 dropped from 100% in the same time, to 98 or 97%. SO in Marshmallow dropping more as 5% and sometime more. This is just in standby mode, when Satmaina is activated and ect. In games dropping really too much, afterm 10 minutes of gaming can drop 1 about 10 - 20% or more.
3. There is problem with Wifi and Bluetooth connection. If is turned on both these connections, can drop Bluetooth connection. About this problem as i know talking more Xperia C5 Ultra owners.
4. In camera you can't turn off sound and do record without any voice and ect. For example: if you want record something, but you don't want to record with extraneous sounds, you can;t, there is not option to turn off. This option was missing.
5. Calculator app at last have % option, but these don't working right. So need another app.
I can't remember all issues which i found, but was little more it.
6. Stamina missed some option which was in Lollipop 5.1, but now is Doze which doing almost the same work as Stamina did.
7. All apps need for now move to SD card separately, there is no option as was in Lollipop 5.1 to move all apps together.
After update was fixed some issues which i found in Lollipop 5.1:
1. Problem with notifications
2. Problem with improvement of the image (Bravia Engine 2 and Super Vivid)
To update yours smartphone you can with Xperia Companion in yours PC
