Hi guys,
Need your help here.. Anybody know what to do or have any solution to my problem?
My Sony xperia c5 cant charging when its on. but if i turn off the phone, its will charging the phone. Just happen tonight.
Any solution?
Thanks
Hi F4yri5h,
Welcome to the community,
Have you tried different ways of charging the device, say using a PC instead of a wall charge and if you have did you get the same results?
hey i am having the same problem from 1 day ....my phone is getting charged when it is turned off but it is not charging while it is on...and also not in safe mode...plzz sony give me a solution
I tried to connect the charge and even with pc.still npt charging when on? need a solution
hi
I had the same problem when as you did today,
Try simplying swtiching the charger, for me that worked, hopes it works for you!
Thanks
