Unfortunately after upgrading to marshmallow android there is no sign of the remained time of full charging on lock screen,even after reset factory...
@Behnambbb Check this out:
/t5/Xperia-Z3/Left-time-to-complete-the-charge/m-p/1091747/highlight/true#M29049
It should be available in 6.0 though. Let me check with some friends.
Hi @Behnambbb,
Could you send me your device's IMEI in a PM? I can then request more information about this.
hi Benhambb, in my past experience, this usually happens when the theme you are using has a modified lockscreen. could you try in safe mode with a default theme that came with the phone and charge it.
@YoGem That could be the case. I've requested more information about this so I'll post here as soon as I know more.
Hi everyone. I received information today that the estimated charging time displayed on the lock screen has been removed from some devices running on Android 6.0. These devices are Xperia C4, Xperia C5 Ultra and Xperia XA Ultra.
