problem with internal device memory
kunal_kv
Visitor
I am getting problem with internal device memory in my sony xperia c. I am pissed of with limited storage to install apps!! Help me to clear internal storage or to uninstall unused apps which came as default!! ASAP
Tags (1)
92 REPLIES 92
Toffee_Goodboy
Visitor
Sony Xperia C always run out on internal memory and it is preventing APPs installation even onto Micro SD card.  Any other work around for this phone?
ahmed-samy
Visitor
i have the same problem why don`t they make them merged please any one got solutions reply
Hari_xperia
Visitor
Hi All,
             After many mail thread i dont think so ,a porper response from sony regarding space issue.
hence i tried a workaround to overcome this issue. it worked great :smileyhappy:
My sister had android phone where she installed (app sender) app.  I send her installed app via app sender and recived the same via bluetooth in sony xperia C and installed the app.
I had internal memory of lesser than 100mb . the app is getting installed in SD card. i hope this workaround would help .
i have learnt a lesson that i should not trust sony from this product.
kirti080808
Visitor
 my mobile memory shown when i try two download  to download new apps& updates of apps  my device has not support it  shows devoice memory is insufficent but there devoice memory is some space is there
Uliwooly
As long as you have less than 50 or 60MB you will continue to get the same message
sbhpeter
Visitor
I have 8MB memory card in my device. 6MB is free now. But when I try to download apps it show no enough memory.
Uliwooly
That's not enough memory
XperiaCLowmemor
Visitor
WHERE IS SONY SOLUTION??????????????????
ALL USER HAVE SAME PROBLEM
U MUST RESPECT WHO TRUST U AND BUY YOUR PHONE
OR I WILL NEVER BUY ANY SONY BRAND
skumar_83
Visitor
Hi all,
Even though there is 100 MB of space on my xperia c phone, am not able to install any apps..everytime i try to install an app, i get this 'Insufficent space in device', the device android version is 4.2.2 (16.0.B.2.16 build).
This happening after the above buld was updated. Is there a solution to reslove this issue, I cannot use my phone this way.....
Tags (1)
Thommo
Not sure it will fix your predicament however you could try using Clean master from the Play store to clean out the cache and any other old files - This may fix your issue but I can't be sure
