problem with internal device memory
kunal_kv
Visitor
I am getting problem with internal device memory in my sony xperia c. I am pissed of with limited storage to install apps!! Help me to clear internal storage or to uninstall unused apps which came as default!! ASAP
Tags (1)
92 REPLIES 92
MostafaMohamed
Visitor
Hi
I need to know if there is a method to increase the device memory of my Xperia C smartphone as in this situation I can't even update my already existing applications so sony corporation must have a hardware or software solution for this solution
Thanks
profile.country.RO.title
_alexdon_
You cannot do anything officially,the option would be rooting your phone,but that means warranty will be gone.
alexdon
XxCLEAVONANDxX
Visitor
Its easy just go to the place you goto uninstall apps then swipe your screen until you come to SD card then you might see apps which are ticked and some not click on the ones not ticked then youll see and option saying transfer to memory card click on that and youre done =D
Bappymondol
Visitor
Prefferd install memory changed to SD Card, but till now not install more apps
OmidOracle
Visitor
I have the same problem. Xperia mobile divine its internal storage to Two to part 998 megabyte and other to1.25 gigabyte. The 1.25 gigabyte is unusable in all the time. I saw other branded mobile that doesn't do that. It give the customers enough space. Like huawei 525. 2.2 gigabyte internal storage. A3000h Lenovo. 16 gigabyte.
If Xperia group merge this two part to together. This problem solve Completely. if any new update come.
Thx.
babu222
Visitor
same problem here
google play service and store getting bigger day by day
with 988mb space we cant install more apps
i_am_angel_2402
Visitor
i had app2sd and moving some apps wont do any change. it's frustrating coz it always say STORAGE RUNNING OUT
csp567
Visitor
how to access to root, please tell me the steps to get access to root., I am facing memory issue.
djdee0304
Visitor
GO TO APPLICATION AND DOWNLOADED APPS SUCH AS FACEBOOK IG CHROME WECHAT OR ANY BIG APPLICATIOn DOWNLOADED AND SD CARD THEN CLEAR DATA!!!! YOU NOTICE UR DEVICE MEMORY WILL INCREASE! SO U CAN NOW DL AnD UPDATE NEW APPS
PROBLEM SOLVE!!!
Pareshgh
Visitor
Hi Team,
I have Sony Xperia C. My internet storage use only upto 0.98Gb. while installating any application its show internal memory full.
Please sugget solution for the same.
Thanks
Paresh
