Photo deleted after update
Lokman
Visitor
All my photo album were trouble after auto updating from sony centre. Only a few were save..while others only in thumbnails. Please help me to recover the files.
1 REPLY 1
Uliwooly
@Lokman
I'm sorry to hear about your issue, but the update wouldn't delete your data, with that said, did you used Xperia Companion or through the phone ? if you used XC then it should give you 2 options, clean update or just to install the update, it won't update by itself.
As for recovering the pictures, there's no way to do so unless you already have root access, and even then it might not work.
