Overheating and slow charging
andribs
Visitor
Hp saya membutuhkan waktu yg lama untuk melakukan charging baterai serta tidak mau connect dengan kabel otg
My hp takes a long time to do the battery charging and do not want to connect with otg cable
3 REPLIES 3
Uliwooly
@andribs
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
That's normal, charging through a computer will take quite a bit of time as compared to a wall charger.
Not applicable
@uliwooly wrote:
@andribs
With charger is the same. Sometime to full charge C5 Ultra need more than 3 hours, somedays and 5 hours, even when you using in the same time it 🙂
Not applicable
When you using a lot smartphone it's normal that it heating, a lot... leave for a while to little cool down it... About charging... Keep in mind that C5 Ultra havn't quick charger feature, but have big battery... it's normal that you have to charge little longer as others models with less battery capacity or with quick charger 😉
