I can't find anything about that here:
http://www-support-downloads.sonymobile.com/e5303/whitepaper_EN_e5303_e5306_e5353_xperia_c4.pdf
Perhaps @Jake-SonyXperiaSupport knows more.
Hi Guys,
From what I can find on the User Guide, the device can use USB Host which does allow the use of USB OTG cables.
I hope this helps.
Not a problem, glad we could help
Hi,
I tried USB memory sticks (FAT & FAT32), SD cards and directly to an Alpha camera. I used 2 different otg cables. No OTG at all.. Has anyone seen it work on a C4 DUAL (E5333)?
<edit>Today I say it working with a lend otg-SD-cardreader. So, the challenge is to find a working OTG cable... <\edit>
Paul
OTG SUPPORTING .. JUST CHECKED AND TESTED .. ( ON XPERIA C4 DUEL)
Dear,
Can I Use San Disk Pendrive (which is OTG enable) in My C4 DUAL?
