- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The light doesn't turn off after full charge, but reaching 100% means it is fully charged.
If you change to another adapter from sony with 1500 mA output, it will completely charge in about 2 hours.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Green light won't turn off when it has reached full charged state. But when it reaches 100%, it is ok to disconnect. You can go to settings - about phone - status and there it should say, under battery level.
About charging time, are you charging with an original sony adapter?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That is normal, 850 mA will charge the battery of almost 3000 mAh in about 4 hours. You can buy another adapter from sony, with an output of 1500 mA, which should improve the charging time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Tamer2015 Please read my above post too. We usually recommend people to use only original sony chargers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It is healthy as long as you use sony adapters only. You can also use other adapters, but that won't grant you the charging experience or the battery life.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
