How to trace lost Xperia C4
Ilove2606
Visitor
I am unable to trace my Sony Xperia C4..which was lost on 10th March. I was unaware of Sony Xperia C4. Detection either tracing it out.My confidential photos nd messages were there. AS I'm woman you understand how can it trouble me!!Plz help me out.Ive filed complaint against this in local police station..
3 REPLIES 3
Emir1
Hero
Hi @Ilove2606, I am very sorry to hear about what has happened. Slightly_frowning_Face
I am afraid that I do not have a way to trace your device, but you may try locating your device using our my Xperia service as well as the Google Device Manager service. I will provide links to both below:
my Xperia
Both the services listed allows you to try to trace your device, but also lock the device and erase all the stored data.
For Google Device Manager, login using the Google Credentials which you used in your device and choose your device > Enable Lock & Erase > Lock / Erase. It will also present you with a map for tracing.
For my Xperia, select your device after logging in > Erase.
Note that both services require the device to have an active Internet connection, but you can queue up a service if it's not available at the time, and you will then be sent an Email once it is available again.
In addition, I recommend contacting your operator and police to see if they can disable the IMEI for you, and also contact the Local support to see if they have some more courses of action which they may suggest for you.
Let me know if that helps! Feel free to kudo my post and mark it as the accepted solution if you found it useful so that other users may find my post as well. Slightly_smiling_Face
Manju013
Visitor
My mobile Los last year now sambade was saptamber morning How I Kan trace
Emir1
Hero
Hi @Manju013, I'm sorry to hear that. Slightly_frowning_Face
Have you had the opportunity to read my post here for advice on things to try? However, please note that if it has been over a year, the device is likely to be powered off if it has not been found, and in such cases the services mentioned in my previous posts will not be able to locate it. Slightly_frowning_Face
Let me know how it went! Slightly_smiling_Face
