La memoria de mi teléfono me aparece llena pero tengo una extraible de 32 gb por más que paso fotos y aplicaciones sigue llena
La batería no dura
Pffff odio este teléfono
The memory of my phone appears full but I have a 32GB removable for more that pass photos and applications is still full
The battery does not last
Pffff I hate this phone
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Settings > storage > tap on the graph > how much free storage do you have?
also clear the cache
and last
Settings > apps > look for social media and streaming apps > storage > clear data > repeat as needed.
@Pame16 look that @uliwooly gave you the right solution. I own the C5 too and I did no have such problems but I am not an avid user of Social Networks and it's known that Facebook, and others, usually grow in space used every single day. Also, I know you may have a 32GB SD card but apps are not installed in the SD Card but in the Internal Storage.
So, best approach here? From time to time do what UliWooly advised, and try to keep installed only the app you really need - the C5 is a good phone and 16gb storage is not that bad.
