Error " Cannot record. Recording or recording related function maybe in use by another application".
OPGELOST
Shaggyd
Bezoeker
Can not use recording. Restared phine still issue.plz help
Tags (1)
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
YoGem
Leider
I explained it... Anyway, try this. Go in your apps, search one app called Google, should have a big G as icon. It will show you "Google Now". You will have a button on the top left, it's a 3 horizontal lines. Tap it, the go to Settings, then voice, then ok Google detection..
Disable everything that is enabled and try again to record.
5 ANTWOORDEN 5
YoGem
Leider
If you are still with lollipop you may have ok Google voice recognition active.
Long press the home button until you go to Google now, go in settings and disable voice recognition.
Does it work now?
Shaggyd
Bezoeker
Yes i m using lolipop where would I find the optiin ti disable voice recognition. Plz help with detailed steps.
YoGem
Leider
Shaggyd
Bezoeker
Thank you friend. It worked.
0394
Bezoeker
I want to use that 'ok google ' option. In that case I can't use video recording?? means this phone is waste of money..
