Camera button not working
SOLVED
Sahil1
Visitor
Hello, I bought Sony xperia C5 ultra just day before yesterday. I am not able to click pictures by pressing the camera button provided below the volume rocker. When I press the button, flash light flashes but the picture doesn't capture. Is there any setting to activate the camera button or is there any problem in my new phone??
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Ok,try settings-apps-all-camera,force stop and clear data. Restart and check.
alexdon
6 REPLIES 6
_alexdon_
There are 2 phases: focus and shoot. Half press will focus and start the flash, full press should take the picture.
alexdon
Sahil1
Visitor
Sir, when i full press the button then also it doesn't take the picture.
_alexdon_
alexdon
Sahil1
Visitor
Thank you so much sir. It worked for me. 🙂
_alexdon_
Cool.
alexdon
misxcho
Visitor
Hello, i am experiencing the same problem, i try to force stop and clear data, and restart, long press, anything. But still it doesnt work . Is there any method to fix this ?
