Hi,
I'm unable to use the sloth 1 of my Sony Alpha 3. But able to use sloth 2 with the same memory card.
It display an error: unable to read memory card.
Thanks in advance for your reply.
Hi, are you sure the SD card you use is UHS-I or UHS-II?
As mentioned here :
Supports SD cards only (compatible with UHS-I and UHS-II)
Supports SD cards (compatible with UHS-I) and Memory Stick PRO Duo media
As mentioned here :
Oh, though they accept the same format.
My card is an UHS-1, I think.
It is an SD HC 1 integral Ultima pro.
So should work ...
Or not, I'll try other cards. Thank you
OK. Did you try to format it in slot 2, then put it in slot 1 to check?
Don't work. But it is as you said. Mine is a Class C type not an UHS.
Thanks for your time
