- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
XF9005 Vs XG8095
Which of these TV's is the best to buy. XF9005 is 2018 model has X1 extreme processor but XG8096 is 2019 model but doesn't have a sperate processor. Help please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@dmezluv wrote:Which of these TV's is the best to buy. XF9005 is 2018 model has X1 extreme processor but XG8096 is 2019 model but doesn't have a sperate processor. Help please
Hi @dmezluv
In general terms the LED specs are:
Xx7 = Entry Level Spec.
Xx8 = Medium Level Spec
Xx9 = High Level Spec
The number following the 7/8/9 means even higher spec so Xx95 has a better spec than Xx90.
The XF9005 has the far superior VA panel with deeper blacks etc. The XG8096 has an ordinary IPS panel.
https://www.displayspecifications.com/en/model/f4fd1835
https://www.displayspecifications.com/en/model/47c210f5
To me the XF9005 is a no brainer unless you want to wait for the XG9005 or better still the available XG9505.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As mentioned above, XF90 is equiped with superior quality panel and processor, while XG80 has IPS.
I`ve made same mistake last year not buying XF90 instead of XF85.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
For those looking to buy a 2019 Sony BRAVIA TV, I strongly recommend either the XG85 or XG95 models compared to the XG80 and XG90. The reason being the updated hardware on the XG85 and XG95 models which has a significant impact compared to the previous generation hardware implemented on the XG80 and XG90. The difference between an XG90 and XF90 is in real use-case scenario: negligible.
Cheers,
Dutchice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
4K Sony Model naming.
KD = 4K whereas KDL = HD
Were looking at 4K models per year following on from the spec.
KD XG = 2019
KD XF = 2018
KD XE = 2017
KD XD = 2016
so KD - 49 - XG - 9005 (KD49XG9005)
is 4K - 49inch - 2019 model - High Spec
I have the KD49XG9005.
im in desperate need to fix the best picture settings on this TV,
as the picture on Sky Q was better on my old KDL43W809C,
a brilliant Android 2015 Full HD TV.
This should not be the case!!!!!
PLEASE HELP!!!!!
