Hi just had my x94j replaced about 2 weeks ago and have noticed a stuck pixel. Any way to fix this..? 🤔
Solved! Go to Solution.
Thanks for your reply, I have spoken to sony and they advised the same thing. But it didn't work, so told sony and there going to replace it as only had 3 weeks..
Hey there,
Glad that they're gonna replace it for you, but since it's only 3 weeks you can also check what your retailer got to say if it's still within return period.
Cheers.
