V3.865 Update
profile.country.AT.title
Kuschelmonschter
Held
V3.865 Update
Ich halte hier mal meine Beobachtungen zum neuen V3.865 Update fest.
USB installation … partly ok (see comments below)
Voice control after installation … ok
DTS Passthrough via AudioTrack API … not ok
2.35:1 stretch in Video app … not ok
USB write permissions … not ok
USB compatibility issue … not ok
USB storage not accessilbe after deep standby (scheduled recording problem) ... not ok
Double info OSD when switching favorites via DISCOVER … not ok
Guide channel list always reverting from favorites to full ... not ok
SideView app remote empty app list … not ok
The TV doesn't start the update automatically when plugging in the USB pen drive (tested with FAT32 and NTFS). Only Marshmallow's "open with" screen is shown. Only a complete reboot of the TV (power cycle or long power button press) with USB pen drive plugged in made the update start.
The update reverts the digital audio output option to PCM. In order to enable Dolby Passthrough, it might be necessary to set it to one of the auto options again.
Some of my USB pen drives, which worked properly under Lollipop, cannot be accessed under Marshmallow anymore. These are detected as SMI within Android's storage manager.
The Grand Tour on Amazon Video in 4K with Dolby Passthrough suddenly works much better for me. Amazon Video app is still the same version though (4.1.70). So I assume there might also be other influences as other people are still suffering from playback issues.
For further issues check out my bug tracker.
35 ANTWOORDEN 35
kammi73
Lid
aschberg62 schrieb:
Guten Abend an alle,
ist nun der Effekt weg, das beim Drücken der Guide Taste Bild und Ton ausgeblendet wird ?
Habe das Update noch nicht installiert da mein Fernseher meist läuft .
Das lahmende Android Betriebssystem wird wohl kaum schneller werden.
Ich nutze daher oft zum Zappen einen externen Receiver und der Fernseher kennt kein Standby. Wird abends vom Netz getrennt. Sky mit AC Light wird fast immer erkannt.
Ja, bei mir ist das weg!
XD9305UB900
Amazon Video 4K + Dolby Passthrough (The Grand Tour) … ok
@Kuschelmonschter
Du hast geschrieben das Amazon OK ist, heißt es die Ruckler beim Start und die Ruckler bei der Lautstärken-Änderung sind in dieser Version ok?
Sorry das ich nochmal nachfrage
________________________________________________________________________________________
KD65-XD9305, V3.843, LAN, kein Google Konto, SAT, CI+ Modul, Bose 5.1, Synology 415+
Also bei mir läuft Amazon definitiv nicht besser. Ruckler sind noch da.
Kuschelmonschter
Held
Bei mir läuft The Grand Tour auf Amazon in 4K mit Dolby Passthrough momentan synchron und bis auf ein paar kleinere Ruckler zwischendurch recht flüssig. Allerdings hat sich weder die Version der Amazon App geändert, noch glaube ich, dass Sony etwas in der Richtung auf systemniveau gefixt hat. Deshalb gehe ich davon, dass das Zufall ist, bzw. noch von etwas anderem abhängt. Oder es gibt bei Amazon serverseitige Änderungen. Allerdings gibt es auch nach wie vor Negativberichte...
Tomt12
Lid
Hallo ist da was an mir vorbeigegangen? wo gibt es das Update für meinen
KD-49X8309C
Kuschelmonschter
Held
KD-49X8309C Support Seiten
Ist es wirklich so schwierig? Oder einfach nur Faulheit?
