Trying to link Sony Bravia KD-43XF8796 Android TV to Sony account.
OPGELOST
Eewec_Ourbyni
Home -> Sony Select -> More apps -> Activate Enhanced Features -> "five digit code"
https://www.playstation.com/en-gb/ -> My Character Icon -> Account Settings -> Login -> Devices -> HDTVs -> Activate an HDTV -> Enter "five digit code" -> Result; "This device is not currently supported in the country/region associated with your account."
Home -> Playstation Video -> Sign in -> "Do you already have an account?"; "yes" -> "You must perform an update to use the application(Account Manager). Do you want to update now?"; "Update" -> "Full description".... no other option.... ?
Anyone got any other ideas on how to get a TV bought in the UK from a main UK supplier (Curry's) linked to a UK account on the UK web site?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Nobody42
Hi,
Managed to get signed in on my KD-43XF8096.
Go to
Settings, Apps, Find Sony Account Manager & remove installed updates.
Next Go To
Setting, Accounts, Add Sony Account, should ask you to install Sony Account Manager update & should actual give you an install option.
I was then able to sign into my Sony account & Playstation Video.
Hope it works for you.
Martin.
3 ANTWOORDEN 3
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
It might be worth posting your question on the Sony PlayStation forum here also.
Best wishes,
Sean Mc
Nobody42
Hi,
Go to
Next Go To
Martin.
Eewec_Ourbyni
Thank you for posting this fix. Worked brilliantly!
