KD-65XG8096 ei löydä sony WH-1000mx2 Bluetooth kuulokkeita!!
Kaikki mahdollinen on kokeiltu ,missä vika?
Please write your question in English in the UK forum.
In any case your tv does not support any kind of bluetooth audio device since it does not have the needed A2DP bluetooth profile
KD-65XG8096 can't find sony WH-1000mx2 Bluetooth headset !!
Everything possible has been tried, where is the fault?
i don't understand why sony doesn't support sony devices 😞
what does it means ?
Simply the entry level model you bought doesn't have Bluetooth A2DP support for any headphones, not Sony ones in particular. You should have bought an higher model (or a newer one since 2020's model have now an extended support), or if you were advised wrongly by the seller you should make a claim to him
Alright. I'm buying new headphones.
Thank you for the information.
Br. Pirkko
I hope my post was clear enough. Buying a new bluetooth headphone set won't solve the problem with your tv
Yes it is, thank you.
