- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
August
August
sony xh90 x900h missing features since recent update v6.2266
Spoiler
updated during July, since then i have no quick settings via remote or external input via menu or remote, or if i use the sony dn1080 av amplifier home button, tv will not change to show amplifier home menu settings. why did sony release this update, or why does my tv behave with faulty firmware. i need to redo the update process or something else. everything i want needs quick settings so i can adjust the picture settings.
help button or Netflix, Google play, external input, quick settings, dont work on the remote. onscreen, external input dont work.
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August
August
ok so i redownloaded the update usb files, attempted update, tv did not redo update because its updated and matches same firmware version.
checked in all apps for quick settings (com.dtv.quick not there) but cleared data for system update and ui.
left firmware usb connected (dont think it updated) , reset internal storage, reset to factory, completed initial setup, pressed the buttons that were not working, now everything is working.
redoing my setup today, external ssd(device storage) , apps, custom pictures for all apps, picture modes (vision, hdr, +, etc) and sources, sounds, avr, shield.
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August
August
yes everything is working as it should be
