Sony BRAVIA KD43XD8305BU & PS4 PRO
OPGELOST
avi1508
Hi, I have a Sony BRAVIA KD43XD8305BU which i use my PS4 Pro on - When going into the HDR settings on the console, it only shows as supporting 2K HDR - With 4K HDR not supported? Is there a setting on the TV which changes this to 4K HDR? The TV Supports full 4K.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Hi,
you need to set the HDMI input to "enhanced mode" in the settings menu.
Everything should be fine after doing so.
Cheers
4 ANTWOORDEN 4
Hi,
Cheers
avi1508
Hi Peter,
Thank you for your comment. Will do that and get back to you if it works.
Kind Regards
Afzal Hussain
avi1508
I noticed it was because of the HDMI Port it was in.The settings were already on "enhanced mode" however HDMI 4 only supports upto 1080p and had to be switched to HDMI 1-3 which i did and it started to display 4K gaming content.
Kind Regards
Afzal Hussain
asmith2475
We have the Sony sound bar too,  HT-NT5. So the PS4 pro goes into the soundbar and then HDMI 4/ARC port.. Which is the only Port soundbar works with. Not too pleased with their set-up considering the amount of $$ spent.
