I bought the A80J and i cant find the Rakuten.tv app. Please consider adding it
It should be already there, contact them if you cannot find it
It's not available for my country (sweden) I hope they add it in the future since j use it on my other tvs
Indee, in Sverige is not listed, but I still think you should ask them why, it should be their interest to have more platform enabled. It is a commercial issue in any case, since technically the app is supported.
As a workaround, you should be able to cast movies from a smartphone to the TV.
Hi Timpann,
Did you try to install it from play store?
Yes
