KD-65XF9005 white problem
FOCACCIE
New
Hi, I'm really sensitive to white, I don't know why but I hate white (is too bright and distracting all the times) and for no reason it makes me angry , has somebody some advice to make the white reddish or greysh, I've tried all the preset warm professional1/2, X-tended Dynamic Range to off, even the advance color calibration did nothing the white color is unchangeable. Sorry for this silly request... :((
1 REPLY 1
Hi,
If you lower brightness and contrast you should get a greyish white.
Also please make sure that the brightness sensor is turned on - else your screen will be very bright at dusk.
Cheers
