Sony Bravia TV Netflix 5.1 to Yamaha receiver audio dropouts problem
ROZWIĄZANE
stuhac
Użytkownik
The audio from the Sony Bravia KDL43WE753 Netflix app keeps dropping out when output to my Yamaha RX-660 receiver in Dolby Digital 5.1. The dropouts last less than a second, but are really annoying as they happen regularly (the time between each dropout seems random. Sometimes the audio is fine for several minutes, but other times they happen every few seconds). I’m currently having to change the tv output to PCM whenever I want to watch Netflix.
Only the tv’s Netflix app has the problem. I don’t have the problem in any of these scenarios:
- Digital Audio Out set to PCM (i.e. not using 5.1)
- Netflix app on my Virgin TiVo box output via hdmi to TV then on to the receiver using the tv’s Digital Audio Out of Auto1 or Auto2 (this was almost a workaround, but the picture quality is very poor from the Virgin box)
- Blu-ray player via hdmi to tv then on to the receiver, as above
- any other 5.1 digital output from the tv (e.g. from HD TV channels)
I’ve done a range of things to try and solve the issue, but nothing’s worked:
- Tried 3 different HDMI and 1 optical cable from the tv to the receiver
- turned ARC and BRAVIA Sync Settings on and off in a variety of different ways
- set Digital Audio Out to either auto1 or auto2
- set Dolby Digital Plus Out to either auto or off
- restoring factory settings
 Does this tv have an unresolved problem with its 5.1 Netflix output, or is there something I need to do?
I’ve run out of ideas, so any help would be much appreciated!
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
stuhac
Użytkownik
Hi all,
After hearing from Sony I got an engineer out from John Lewis, as I'm covered by their parts and labour warranty.
The engineer replaced the mainboard and since then I've had faultless 5.1 surround sound from Netflix.
I guess the moral of the story is that not every apparent software issue actually is one!
Thanks to everyone who offered advice and ideas...
Wyświetl rozwiązanie w oryginalnym poście
37 ODPOW. 37
EdwinaU
Moderator
Hi there,
We'll look into this and let you know what we find.
Perhaps some of our members will have some tips to share too.
Best wishes,
Ed
andrew342003
Poszukiwacz
I've also noticed the same issue recently where the audio on Netflix will drop for half a second, this does not occur if i use netflix on the Virgin V6 box, or if im watching from another app.
TV: KD43XE8004
Reciever: Yamaha RX481D
dutchice
Hi @stuhac,
Let me see if I can help. From your post I understand that you get the drop-outs both when using the Optical Out as well as the HDMI ARC connection from your TV. Correct?
Please try the following and report back your results;
  • Turn off the HDMI-CEC function on the AVR and check for drop-outs.
  • Disconnect ALL HDMI cables connected to your AVR and only connect your TV using the Optical Out connection to your AVR, then check for drop-outs.
  • Post here please the firmware revision of your Yamaha RX-A660 AVR.
Cheers,
Dutchice
stuhac
Użytkownik
Hi Dutchice,
Thanks for your reply. To answer your questions:
- Yes, I get the drop-outs over HDMI and optical out from the TV
- I've turned off all HDMI-CEC on both the Yamaha (HDMI Control) and the TV (Sony Braviasync)
- With all the CEC stuff turned off, I removed all cabling from the Yamaha and the TV other than the optical cable from the TV to the receiver, and the issue still exists.
- My Yamaha is on revision 2.59, which it tells me is the latest version. BTW, the TV is also on the most up-to-date firmware...
Any ideas?
The_Black_Rose
Specjalista
Hi stuhac ,
Could you try unplugging any other devices connected to the TV, I believe you mentioned a Virgin box, and leave only the amplifier and the TV connected and check if the issue is still there?
Cheers,
The_Black_Rose
stuhac
Użytkownik
Hi black rose,
Thanks, but I've already tried that and unfortunately the issue is still there.
Tenneen9000
Użytkownik
Hi stuhac,
Have you spoken to Yamaha support? If you did, can you share with us what they said about this issue?
Cheers,
Tenneen9000
stuhac
Użytkownik
Hi Tenneen,
So far I've spoken to Netflix (who didn't know anything and moved me on to Sony) and Sony, who promised to get back to me within 48 hours (but now at 120 hours with no word from them).
I don't see how this could be a problem with the Yamaha amp given it can faultlessly play audio from every other 5.1 source barring the one from Sony's Netflix app, so haven't contacted them yet. I may contact them once I've exhausted any possible assistance from Sony...
Win_88
Specjalista
Hi Stuhac,
I'll pass this one to my Sony contact to see if there's more that can be done to help.
Cheers,
Win_88
