- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-65X8509C bought within the last week
I have the TV's IR Blaster setup to control a BSkyB Sky+HD box, and most controls work great. However, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always sends 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between.
Is there some way to update the IR blaster database to correctly only send 1 occurrence of LEFT, RIGHT, UP, or DOWN when that button is pressed? Or is there any other solution to this problem, that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@mk_chappo wrote:Did anyone find a way of accessing the Sky Planner / Recorded programs (i.e. like pressing the "Sky" key) directly from the Sony remote? I know you can mimic it from the "Action Menu" but this is quite frustrating.
Anyone?
Just press the 'Back' button on the remote.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've just purchased one of these have the latest firmware and the problem still exists.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi have 55xf8577 running Latest os and tried all the resets but still jumps 3 lines at once, software patch needed Sony in think unless you know how to fix it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry that I cannot help you.
Nick
Sent from Mail for Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all,
Just bought a TV and I'm encountering the same problem in December 2019. System states no update available any other fix suggestions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi All,
Found a fix for this without requiring a full software reset. It seems like the IR blaster App/Service just needs a data reset.
Go to Android Settings (Home button > Settings)
Go to Apps
Scroll down to "IRBlaster Native" , select the app to open further options.
Select Clear Cache & Clear Data
Do the same for "IrbService"
Once both apps are reset, go to the IRBlaster set up again and follow the usual setup process.
That fixed it for me, hope it helps someone else.
Cheers
James
- « Previous
- Next »
