Hi I’m after a bit of tec help. Can I use my iPhone 12 to connect my Sony Bravia via hotspot. I also have sky go which I would like to watch whilst away in our motorhome. Tia Russ
Hi,
Unfortunately you did not name the TV model.
Anyway, please check this article about connecting an iPhone to a TV:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/articles/00044409
Cheers
Not sure if I got your question right, but you can set up a hotspot on your phone using the Apple support guide. Once done, you can just connect to it from your TV as you do with any WiFi network.
Hope this helps!
- JD
