Freeview rescan issue
rfwilmut
Explorer
TV is KD49XE9005. Did a rescan this morning because of the Freeview changes. The set went through the channels add added a number of services, but then took me to a page where it asked me to select a region. I did so, clicked 'Done' and it went back to the screen for starting a scan. On checking I found that the channels were still the old ones. I went through the process again, with the same result. So I put the set into standby then switched it off at the mains. After a short pause I switched the mains on again and booted the set up. Now the new channels were correct - so there isn't now a problem: but it's not supposed to happen like that!
1 REPLY 1
Anonymous
Not applicable
Hi there
Glad its resolved, but I cannot give any explanation for why that occured.  Can only assume that the channels where held in the TVs cache but not stored until just before you rebooted the TV.
Cheers
