cannot upgrade kdx9305c firmware
roops67
Hi
just bought kd65x9305c but cant upgrade the firmware. if done by internet it stops at 81% everytime saying (error 2123) that a problem with server, if done by usb it again stops at 81% copying file and then crashes tv!
please help
9 ANTWOORDEN 9
Anonymous
Niet van toepassing
Hi there
Ive sent you a private message with some instructions.  Let me know how you get on.
Cheers
roops67
thank you Quinnicus but doesnt seem to work as you described 😞
I've replied to your email
roops67
thank You it worked , you rock!
Anonymous
Niet van toepassing
Your Welcome :wink:
didievilempire
Hi.
Quinnicus, I'm from Brazil.
I can apply this solution?
XBR-55X855C
Thanks.
Anonymous
Niet van toepassing
Hi there @didievilempire
Ive sent you a PM, with the instructions.  As you are in Brazil and different firmware etc, I am unsure if it will work or not - but it doesnt hurt to try.  I had 1 person from the USA ask as well, but these instructions failed.
Give it a go anyhow.
Cheers
profile.country.GR.title
dimitrisv99
Hi @Anonymous
I have 55x8005c but cant upgrade the firmware. if done by internet it stops at 67% everytime saying (error 2123) that a problem with server, if done by usb it again stops at 67% copying file(error 2123) and then reboots tv!
please help
thank you
Anonymous
Niet van toepassing
Hi @dimitrisv99
I have sent you a private message with some instructions - let me know how you get on.
Cheers
dimitrisv99
@Anonymousthank you very much!!!!it works for me!!!!you are the best!!!!
