Does anyone know the maximum number of simultaneous recordings onto a SSD HDD?
I don’t really want to test it since I’ve not yet found a way to cancel a recording in progress (my previous post).
Opgelost! Ga naar oplossing.
Only one, the twin tuner is used only for watching a program while recording another. Officially SSD are not supported (only HDD) and are not needed in any case
Thanks for that. It’s actually a HDD not SSD so sorry to confuse things. It’s so small compared to my my old one (which was like a brick) I wrongly assumed it had to be SSD. They don’t say on the box but I should have realised because it was much cheaper.
