L-Mount lenses onto Sony a7riii
SOLVED
SCO1947
Explorer
Any suggestions for loading a L-mount lens (NOT Leica M mount) onto a Sony A7riii.
There does nor seem to be any on Amazon but I have a number of L-Mount lenses I wish to use
with Sony A7riii for manual focusing.
1 ACCEPTED SOLUTION
Accepted Solutions
danardeng
Contributor
If sigma L mount you can pay for mount conversion.
Any other way with adapter that should be only 2mm thin with all electrical contacts and conversions, are not available
2 REPLIES 2
danardeng
Contributor
SCO1947
Explorer
Many thanks for your prompt reply.  I shall try the conversion route.
